repost for the late ,late ,late crowd !!...Hella micro DE fog install(semi-completed)
need to redo the driver side
<img src="http://pictureposter.audiworld.com/27798/mvcfullfog.jpg">
<img src="http://pictureposter.audiworld.com/27798/mvcleftfog.jpg">
<img src="http://pictureposter.audiworld.com/27798/mvcrightfogzoom.jpg">
I wanted to place the fogs in the outer portion of the lower grills but
for the lack of a solid mounting spot on my 97, I opted to use the Bumper support bolts(fogs won't flicker at all) and there's no obstruction of air flow going to the ic
Using a 3 inch pvc tubing ring made for a cleaner grill cut out
I also bought an Audi OEM fog switch with the wire connector block for it which made the interrior install a breeze
Re: Using a 3 inch pvc tubing ring made for a cleaner grill cut out
Looks good, have any pictures of the process itself? How much did it all run you, out the door?
Thanks,
Travis
'99 1.8TQ
Thanks,
Travis
'99 1.8TQ
fogs were $150.00cdn,Audi OEM fog switch $34.00cdn,Audi electrical block for switch $20.00cdn(wires included)<ul><li><a href="http://www.pgperformance.com">http://www.pgperformance.com</a</li></ul>
Pizzicato
01-30-2002 04:02 PM
Pizzicato
01-26-2002 03:24 PM
SmokinS4™
12-27-2001 06:02 PM
Pizzicato
12-17-2001 08:59 PM
