Repost: Where are A4's lift points if you do not use stock jack, but a floor/hydraulic jack?
I have a similar (?)... Is there a jack point in the middle so you can lift two tires...
at the same time? Like lift both fronts at the same time or both rears at the same time?
Huh huh huh... jack...
AudiWorld Expert
Re: My floor jack has groves in the lifting cup. I posistion those on the pinch weld where the stock
are the grooves deep enough for the lifting cup to go around the pinch weld? What jack do you have? Where'd you get it?
I'm not sure of the brand I'll have to look when I get home. It's old though. As for the cup...
The groves are deep enough to fit the pinch weld nicely. At least good enough that I trust my head under there when I change the oil. :-)
Mine are not deep enough to go around the pinch weld. If you want it to do that, you need (m)
...one of these.
<img src="http://www.eastwoodco.com/photos/p2406.JPG">
<i><b>Price: $ 19.99
FLOOR JACK ADAPTER FOR LATE MODEL CARS
Item-no 43042
Unibody vehicles can't be safely lifted with conventional floor jacks - says who? With this Floor Jack Pad Adapter you can safely lift Unibody vehicles with a regular floor jack, without damaging pinch welds, mis-aligning body panels, or damaging suspension components. Adapter's U-channel lifts vehicles at the correct factory-designated lift points. To use, simply remove the saddle insert from the floor jack and insert the pad adapter. Fits jack saddles with 5/8" or 1 1/8" holes (with bushing included).</b></i><ul><li><a href="http://www.eastwoodco.com">Eastwood Company</a></li></ul>
Item-no 43042
Also, how do you place jack stands for the floor jack...
If there is only the pinch weld to lift? As sturdy as floor jacks are, I'd still feel more comfortable with a real jack stand if I'm going to be crawling under my car...
-PhilJ
-PhilJ
