Reprogramming Chip.....Questions
By the way, I also just ordered the TT BPV, and a boost gauge so I'm starting out my mods
The 558M box was available on a limited basis in pre-2000 models. The ECU
can be recoded for use in your car. This will come at a charge of $50 for
our warranty transfer and $50 for recoding. I hope this helps. Let me know
if you have any other questions. Thanks. Jeremy Auvil
Jeremy Auvil
Sales/Customer Consultant
1800-680-7921
www.goapr.com
The question you should ask APR is if the chip programming is different between the two. They said "The ECU can be recoded for use in your car." If they're talking about just the soft-codes, then anyone with a VAG can do that (make the soft-codes on that ECU match what your stock soft codes are). If they're talking about changing out the programming on the chip, someone with an APR programmer may be able to help you (assuming there's a socket on your chip.. open the ECU and check). You'd have to have APR send you the software though, since there's no 558M download on their site (which leads me to believe that it may be the same programming as another box)
