Running temperature
Old Aug 21, 2006 | 09:47 AM
naid's Avatar
Default Running temperature
98.5 30V, temperature usuallly sits at the middle (or just a hair to the right), but sometimes goes over to the next marking on the right and sits there for a while. Eventually, it recovers. Should I be worried?
Also, the radiator fan is almost always on. Coolant seems okay (good level, pink in color). Oil temp is at 200-225.
Old Aug 21, 2006 | 09:51 AM
tobin's Avatar
Default Could be your fan clutch
The needle shouldn't be over halfway unless it's really hot out and you're pushing the car hard. Since your electric fan seems to be fine, Check your main fan to see that the clutch is not worn out. Search for how to do this (just don't ask Mrs. Kris Hansen's mechanic!)
Old Aug 21, 2006 | 09:58 AM
Silver Streakin''s Avatar
Member
how old are the Tstat and coolant temp sensor?
Old Aug 21, 2006 | 10:02 AM
naid's Avatar
Default Not sure, bought the car 2 days ago...
...with 73k miles. Should I look into changing those?
Old Aug 21, 2006 | 10:29 AM
IBG's Avatar
IBG
and the timing belt, wp, tensioners, etc. if they haven't been done already.
Old Aug 21, 2006 | 10:58 AM
jprice@CPS's Avatar
Member
And accessory belts too while you're in there.
Old Aug 21, 2006 | 11:47 AM
naid's Avatar
Default Vendor & mechanic suggestions?
Thanks for the advice! I found these:
http://www.blauparts.com/audi_vw_timing_belt_kits/audi_a4_v6_30v_timing_belt_kit_improved.shtml
and also:
ecstuning.com, ES#6198
Any recommendations? They both look okay, I just haven't heard of either company before (but then, I haven't had an Audi till last week).
Finally, can anyone recommend a good Audi mechanic in Connecticut that can do all this? I live in the Fairfield area.
Old Aug 21, 2006 | 12:17 PM
IBG's Avatar
IBG
Default Ask on the CT or New England board for a shop...
blau parts is decent you could also try Purems.com.
There is Tony's Imported auto in Manchester. Their labor prices are a bit high but the quality of work is well worth it. I'm sure there's a shop closer to Fairfield, though. You could also see if there is anyone who is willing to help you DIY the timing belt job.<ul><li><a href="http://www.tonysimportedauto.com/">http://www.tonysimportedauto.com/</a</li></ul>
Old Aug 21, 2006 | 12:19 PM
jprice@CPS's Avatar
Member
Also check purems.com
vtraudt
Audi allroad
32
Aug 21, 2016 01:09 PM
mikalot2k7
Jun 22, 2007 10:06 AM
HielToh
Jun 10, 2005 08:45 AM
SDS4
10
Jul 12, 2002 05:36 AM
