So is this the best way to pressure test my car for leaks?
Gonna do this on Sunday. Is the link a good method of doing it?
Thanks.<ul><li><a href="https://forums.audiworld.com/a4/msgs/1659806.phtml">https://forums.audiworld.com/a4/msgs/1659806.phtml</a</li></ul>
do you mean compression testing?
unplug your fuel injector connectors & your spark plug/ coil packs... then remove 1 coilpak/plug and turn the engine over... it wont start but you can determine the compression from that.
no pressure test, not compression
I want to check where my vacuum/boost leak is, not the compression of the heads.
With this I will pressure test the intake and look, hear for leaks in hoses.
runoverb4
07-20-2008 03:15 PM
FatAuto
07-25-2007 12:00 PM
adminisTerTurbo
03-01-2007 08:10 AM
back2black
05-02-2004 01:14 PM
