Spark Plug Question!!
I recently purchased an 01 audi a4 Quattro (Turbo) 1.8L, and i want to change the spark plugs.
I originally wanted to try using the Bosch Platinum +4 but as i googled for more info, ive seen several warnings on using them on cars with turbos. My question is... what spark plugs should i use? platinum vs copper? multiple electrodes or simply 1? NGK vs Bosch? If i should use regular old electrodes which ones exactly should i purchase? I would really appreciate any help/advice that i can get. Thnx |
Try this
<ul><li><a href="http://search.audiworld.com/search.html">Search</a></li></ul>
I agree, search first. The short answer for stock is NGK BKR6E's.
Or . . .
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2299748.phtml">Look here</a></li></ul>
Re: Spark Plug Question!!
ok so i made up my mind n got the bkr6e ones but... why arent they copper? did i get the wrong ones. thnx for the help
they should be copper.
Re: they should be copper.
when I also check rockauto.com their bkr6e is also silver the only copper ones are bkr6eS. I the ones I have say bkr6e stock # 6962 the box also say v-power, can I still use these? Wherencan I gt the copper ones?
Any auto parts store should stock them. You may want to call around. reply in subject line.
