Split-Second ARC1 installed
<img src="http://tomasz.data2net.org/gallery-albums/Audi/Picture_003_Large_001.jpg">
Got the ARC1 connected and working. Well, eventually anyways. The first attempt I hooked it up to the existing ground wire and apparently the connector didn't quite go through the shielding. As a result when I turned the ignition on I got "MAF values too high" error code. Redoing the ground connection fixed that.
The MAF signal is a bright green wire in the longer of the two connector on the ECU. It is the only bright green wire with no stripes on that wire loom. I used a inline fuse connector to separate the wire and provide a place for the ARC1 to plug in. This works very well and also allows me to bypass the ARC1 at any time by using a regular fuse in place of the connectors.
<img src="http://tomasz.data2net.org/gallery-albums/Audi/Picture_001_Large.jpg">
The power comes from a blue/black wire in the brown connector in front of the ECU. It is the middle connector of 3 in that location. Unlike regular accessory switches power, this stays hot during cranking, which is very important for the ECU not to throw codes.
I didn't mess with the WOT a/f ratio yet. I'll either need a good a/f gauge or a dyno/wideband O2 to do this, however I was able to improve my idle substentialy. The best setting seems to be +4%. Looking at the VAG O2 readings, it's a setting where they seem to hover closest to 0. This also smooths out the idle and gets rid of jerkiness at low speeds. Since +4% is showing ECU more air then the MAF reads, this means that I'm actually enriching the mixture, right? I always thought it was rich to begin with, so I was quite surprised to find out that apparently it was actually somewhat lean. Is it possible that due to trying to compensate for lean idle the ECU was over-riching at part-throttle and/or WOT? This just shows how little I actually know about how the ECU/MAF/O2 sensors operate. I know I'm running rich at least part of the time, I can tell this by the soot on the exhaust tips. Apparently idle is not one of those times, go figure. I'm glad I didn't decide to buy a larger MAF, that would've made the problem worse instead of better.
