SplitSec 1.8T BCS (Boost Controller)
But, on paper, it looks good (too good to be true??)... For 250$, you get a boost gauge and you can manualy adjust how much boost you want, without any modification to the ECU! Geez, I want that!!
I am going to attempt to show how this little box could do the same thing as a chip...
1) It reads in the data from the engine sensors
2) It is designed with knowledge of the stock chip behavior (all tuner companies know this stuff)
3) It contemplates the input from the engine sensors and resends them to manipulate the ECU to behave how it wants- it doesn't need to change mappings or timings- it just needs to know what those mappings are and how to invoke any given part of them using fake data.
So, I believe it can do all that a chip can do... just from a different location in the system.
It was designed using stock programming to do the same work as a chip and I believe, with my minimal knowledge of the fly-by-wire architecture, that it is possible to manipulate the ECU by "intelligently" faking sensor data.
I bet that a box like this could be programmed to emulate ANY chip and makes more sense architecturally to me than replacing the chip at all- someone should make one of these things that can be reprogrammed in situ. That would be really usefull, imagine being able to change your chip by simply downloading a program off a website! (assuming you trust the company offering the program).
I am going to buy this box. This technology makes sense to me.
-rb
I am pretty sure that with knowledge of the programming of the chip, one could program this "signal conditioner box" to get the chip program to work like any real "tuner chip"
It's just logical. The chip operates on sensor data and if you control the sensor data, you control the chip.
-rb
