Starter problem, no crank, no click, new starter
Hello,
I own a 1998 Audi A4 1.8 and I have a strange problem with the starter motor.
When I try to start the car, the headlights go out as they should, but there is no click from the solenoid and no cranking. I have tried to start it with other batteries from other cars and still no difference. I measured 12V at the wire connector on the solenoid on the starter connected to the ignition key while turning key, 12V at the big positive wire to the starter solenoid and almost no resistance between starter motor surface and battery negative.
By these measurements I thought the starter was bad so I replaced it with a brand new one but still not starting!!! Still no click or crank. Tried with a fresh battery with no luck. I measured the wires again with same result as before.
The car is easily push started and runs great so there is no problem with spark plugs or fuel pump. There shouldn't be a problem with key anti theft programming either as there is no blinking yellow light on the dash.
I appreciate all help I can get!
Hello,
I think it's under/behind the dash somewhere.
Hi! Thanks for the answer!
The relay seems to be working because there is voltage at the positive connection on the solenoid from the ignition when turning the key.
If the relay would be broken there wouldn't be amy current comming through right?
Appreciate the help!
Solved!
Hello again,
I got the new starter out again and tested it and the connections turned out to be in another order than on the original starter motor. I tried connecting the small 12V cable from the ignition to the other small connection on the solenoid and it started without problem. I put the starter back in and the car started up!
Btw, on the 1998 1.8l model without turbo you do not need to remove any part except for the wheel and the wheel cover thing to get to the starter. You can pull the starter out through the wheel well right over the axle.
T
T
Getting ready to do the starter motor on a B5 A4 12v Quattro. (Any tips?). No crank, no click, fuel pump primes, dash lights up, push starts. Haven't measured power at the starter + but the battery guage shows a slight load when key is turned.
S4@last!::Now B7 RS4
09-12-2004 11:57 AM
anthracitecgt
07-25-2004 10:31 AM
Kinetic0510
06-28-2002 09:35 AM
