Still getting oil burning off.
So I changed the valve cover gaskets on my 2.8 avant a good 600-700 miles ago. I checked a few days ago and no more oil burn off. And oil was right at the top of the dip stick. But then yesterday, I noticed the smell of oil in the cabin. Sure enough I see oil burning off directly behind the passenger bank of cylinders.
Cam Adjuster Seals?
Cam Adjuster Seals?
so those cam adjust seals can cause smoke from behind the passenger cyl?
also, is this the article to change them.
Can I re-use my VCGs that I just put in there when I open it up again?<ul><li><a href="https://forums.audiworld.com/a4/msgs/1650707.phtml">https://forums.audiworld.com/a4/msgs/1650707.phtml</a</li></ul>
That is the most common symptom. Your write up shows half the job.
If the Bank 1 seal is leaking, the bank 2 seal is leaking too, most likely. I'd do both.
I am not a huge fan of reusing gaskets, but I might consider it in this case.
Are your PCV breather hoses cracked?
My passenger side hose cracked and I started to smell oil in the cabin at idle, and you could see a small amount of smoke whisping out of it. Since I already had some upgraded ones on the way, I just taped it up with electrical tape and it worked just fine.
Oh right, you've got a 30v...
On my 12v they go from the back of the valve covers to the intake plenum/silencer deal. But If it's the brittle cheapo plastic tube then ya, that's the one.
First time it was smoking because it was broken, then when replacing it I didn't click it down all the way so it was still leaking a little.
myfirstimport
01-19-2004 06:55 PM
Jkay
10-26-2003 04:07 PM
