Switching ecu for dealer visit
I will throw a code right?
Will they know i tampered with the ecu? |
They will know the ECU was without power.
I think the same code is thrown if you disconnect your car battery, which you are supposed to do when you leave it parked for a while. Can anyone here confirm it's the same code?
yes it will throw a code, either drive around for a while and that code will get cleared or clear
the code with a vag com. Then they won't know unless it physically looks like it was tampered with.
But all you have to do is tell the dealer you disconnected your
battery. BTW I have yet to see the code just go away by itself.
It does go away by itself eventually. Typically several weeks of driving.
I have had my ecu out more then 1000 times
and have yet to see that happen. I took my ecu out about 3 weeks ago(dec 6) and have not cleared any codes yet since my CEL is still on because I dont have the 2nd 02 sensor in the exhaust right now. I will check it again to see if the low power code is still there.
It has something to do with the # of warmup cycles the car goes thru.
I ran a little experiment myself to see if the low volt code would go away, and it took close to 2 months for my code to disappear.
I guess i need to find someone with a VAG
