symphony II problems
The other day my symphony II (Bose) didn't turn on. I did the fuse "fix" and it worked. Next time I turned the car on same problem and i "fixed" it again. I went back and forth with this over a couple days (sometimes everything would work normally). Then it just stopped working all together.
I finally managed to pull the full radio out (huge pain). Pulled/re-inserted the fuse on that one (7.5amp), no luck still nothing. Are there any other fuses that might be associated with this? all other electrical systems seem to be functioning normally. Any suggestions before I go looking for a voltmeter to actually test for power?
I'm also posting this in the audio section... and I have done multiple searches on this subject.
Thanks for the help!
