thoughts???
Old Jan 31, 2011 | 11:38 PM
omzzy05's Avatar
Default thoughts???
ok...long story short..
new car...no problems...changed battery..drving to the mountains 1st long trip...2 hr drive in the hot aussie sun..after a certain point on the lights it goes off and wont start..all mechanic closed it was new years...im in this town..i keep trying...but wont start..so I sit a side and remember something that its not getting fuel...so i locate the throttle cable and move it slightly and car get going..
NOW the question is..i searched all over to locate the idle screw...but couldnt find it...my RPM is about 400-500 at neutral (its Automatic)..Audi A4 1996...does anyone have a clue...I also searched the internet with no luck!!!! boohoo..why does it do this in the heat?? i think the cable slightly stretches causing the car to stall
Old Feb 1, 2011 | 04:53 AM
mtroxel's Avatar
Not sure what you've got going there, but I am sure you aren't going to find the idle screw. There isn't one. That pretty much went out with carburetors. The world is controlled by idle motors and idle valves now. There is an idle speed basic setting you can do with a VAG-COM, but if you're real problem is a stretched throttle cable, check out this .pdf.
Old Feb 1, 2011 | 05:01 AM
AudiMick's Avatar
If it's a 96 V6 clean / replace the idle control valve and check the vacuum lines. Should idle at round 900 rpm with the AC on, slightly less with no AC.
Old Feb 1, 2011 | 11:49 PM
omzzy05's Avatar
hehhe...damn feel kinda dumb...like wasting half an hour looking for something not there..but know i feel better...thanks...ya got VAG-com..ill try and see how it goes..i think its pretty low at 400..
Old Feb 1, 2011 | 11:54 PM
omzzy05's Avatar
replace the idle control valve...and check the vacum lines...
ill try cleaniing it if its not a difficult job...and hopefully it will be alright...fingers crossed...
Q2. I only can spot two sparks...is it me...or does Audi somehow like hiding every freaking part...
90qt
Dec 14, 2004 08:59 PM
SilS4
9
Jul 27, 2003 09:28 AM
Avant Sport
Apr 25, 2003 04:37 PM
Afroney
Nov 7, 2002 03:22 PM
GrantlyS4
18
Jan 18, 2002 12:08 PM
