timing question
Old Sep 3, 2011 | 11:29 PM
4circles's Avatar
Default timing question
If you already know the timing on the crank is off by who knows how much maybe a little, maybe a lot, Is there a way to find the proper alignment for the crank with the cam timing mark on a 1.8T AWM?
Old Sep 4, 2011 | 03:05 AM
4Driver4's Avatar
Tech Guru
Tech Guru
What do you mean? The crank is generally the reference point so it can't really be off. Are you saying that the cam is out of time with crank? Use the timing marks to reset the belt correctly.
Old Sep 4, 2011 | 06:35 AM
4circles's Avatar
Yes the cam is out of timing with the crank and I dont trust that if the crank pulley and the cam marks are in line its timed properly since when I went back to check my work again, the timing marks were both on yet cel said intake camshaft position timing - over advanced bank 1
Old Sep 4, 2011 | 12:48 PM
4circles's Avatar
On a side note, does the timing belt tensioner, after pulling the pin, a one time use tensioner since I cant find a way to push it back in?
Old Sep 4, 2011 | 05:44 PM
mtroxel's Avatar
You can put it in a vice and push it back in....slowly. Push it till there's real resistance, then wait 5 minutes, then push some more. Keep it up till you can get the pin back in. But go slowly or you ruin it.
Old Sep 13, 2011 | 07:32 AM
4circles's Avatar
vice trick worked like a charm. Thank you!
rusty1428
30v V6 Discussion
Apr 3, 2015 12:47 AM
bsherwoo
Aug 14, 2008 10:08 AM
galvan11
Jul 26, 2008 10:49 AM
TT_Nuge
29
Aug 16, 2006 09:59 AM
Xymox007
Jan 8, 2003 08:35 AM
