Tip Chip
Old Sep 13, 2004 | 06:37 PM
Eze's Avatar
Eze
New Member
Default Tip Chip
i was looking in to a GIAC chip, but i have a tiptronic and i was wondering if that was the only option open to me or if i could still go witht the X chip?
Old Sep 13, 2004 | 06:44 PM
[ej257]'s Avatar
Member
Default Engine chips (like the X, etc), and the "tip" chips are for different purposes.
One is for the engine ECU and alters boost, timing, etc. The other is a transmission chip that alters the shifting response while in tiptronic mode. They are unrelated.
You can do one or the other, or both.
Old Sep 13, 2004 | 06:46 PM
Eze's Avatar
Eze
New Member
Default Re: Engine chips (like the X, etc), and the "tip" chips are for different purposes.
Oh, well thats wonderful, didnt know you could do them both. well that makes things easier. Are you 100% sure i can do them both
Old Sep 13, 2004 | 06:52 PM
SDS's Avatar
SDS
Yes you can. One is the tip chip. That makes the lag time on the tip shifting faster. So you get increase in how quickly the transmission will shift gears.
The other is for the engine. It will increase your rev limiter to 7100 rpms, removes your electronic governer and also gives you a 10hp gain.
They can both be installed because they serve different purposes.
Old Sep 13, 2004 | 06:53 PM
[ej257]'s Avatar
Member
150% positive.
[ej257]'s Avatar
Member
Gives you a hell of a lot more than 10hp gain on the 1.8T.
Old Sep 13, 2004 | 06:55 PM
SDS's Avatar
SDS
Default Re: Gives you a hell of a lot more than 10hp gain on the 1.8T.
Depends on the model. Maybe I missed it. If you have a 2.8 it only gives a 10hp gain according to GIAC. If you have a 1.8T, it's like 70 or something.
Old Sep 13, 2004 | 06:56 PM
[ej257]'s Avatar
Member
Do some research.
Old Sep 13, 2004 | 06:57 PM
SDS's Avatar
SDS
Default Re: Do some research.
Me or the other guy? I did research cuz I was looking at a GIAC chip for my car. I have the 2.8 Avant and it says the chip only increases the HP by 10.
Old Sep 13, 2004 | 07:00 PM
DON2.0T's Avatar
wow 70 hp gain on a chip i don't think so
