Tranny cooler problem.......96 A4 2.8
<center><img src="http://pictureposter.audiworld.com/124230/p9290408.jpg"></center><p>Today im in the midst of changing my radiator... All went well relativly untill the last step. When putting back the car i noticed a little drip on the tranny cooler,Damn It....
When you start the car and the pump starts working man.... it is like a little fountain fu.... Please ideas in how to tackle this are appreciated, i was thinking some type of sealing bond untill i can find a used tranny cooler. Thanks |
Reason 1,345 to stay away from slush boxes......However
Is that one of the trans lines??
step 1: cut line(where is cracked) step 2: grab 2 inch(lengh) fuel line hose step 3: use the hose to connect the cut you made step 4: use 2 hose clamps step 5: the fix will outlast the vehicles life |
I second this fix, should be more than enough
Awsome.....Actually
i decided to upgrad to a better tranny cooler. 30 bucks at Autozone. I will let you guys know how it works and if it's worth it, so far so good......
Thanks |
it's the side of the tranny cooler
under the consenser...Good feedback
I really appreciate it........ Thank you |
