trunk problem
Old Aug 18, 2005 | 08:41 AM
darkstyle's Avatar
New Member
Default trunk problem
ok how can i open my trunk?
i unlock it from the driver door
and when i try to open it manually it doesnt work.. and my key does not work also?
i can access to the trunk by the inside of the car but.. i want to open the damn trunk
im sure there is a way to open it other way
Old Aug 18, 2005 | 08:44 AM
Troy H's Avatar
Trunk Monkey?
Old Aug 18, 2005 | 08:50 AM
darkstyle's Avatar
New Member
hahaha funny that doesnt help =)
Old Aug 18, 2005 | 08:56 AM
WJM's Avatar
WJM
Tech Guru
Default you could... sit down for this one....
get it fixed?
Monkeyboy's Avatar
Default Once you get it open....
Find out what the real cause is...
May simply need to be lubed, or there could be a problem with the vacuum line / actuator / etc. for the trunk lock...throwing any codes? Your other locks work OK?<ul><li><a href="http://home.comcast.net/~thomapa1/Centrallockingsystem.pdf">central locking system info</a></li></ul>
Old Aug 18, 2005 | 09:13 AM
AudiDreamr's Avatar
Default Do you have a release inside the trunk?
Maybe something got jammed in the closing mechanism so it jammed shut? Also, how does it "not work"? Does the button push with normal clicking and resistance, or is there little/no resistance? Good luck!
Squalo
Audi A3 / S3 / RS 3 MKII
9
Aug 25, 2022 01:19 AM
WannaS6
A6 (C7 Platform) Discussion
26
May 29, 2020 04:51 AM
tonycosta1984
Audi Original "S" Cars
May 22, 2013 12:07 AM
audimonster100
Audi 100 / A6 (C4 Platform)
11
May 28, 2008 05:20 PM
