Understanding differences between Audi A4 clusters and the compatibility issues
#101
otherwise will be pointless to install the wiper stalk
#102
Hey audifirst. Quick question. I have a 2001 cluster and want to know what the pin outs are for the lighting? I want to make my cluster lights turn on when I start the car so the locations I would need are the lighting pin and a switched power pin. I tried to decipher the manual but all that are mentioned are Terminal XX and Terminal YY and I don't know what those are. I thought I'd ask here before getting out the multi meter. Let me know if you know. Thanks.
Doug
Doug
#103
Hello
I have a problem with a cluster on my audi a4 b5 2000/5. I have found out that something is emptying my batery to fast and all is indicating on the cluster. When i disconected the green conector on the cluster the curent felt from 0,24 mA to 0,04 mA. If anybody had that problem or maybe know a solution please share.
#104
Wondering if you can help me. I have an instrument cluster (8DO 920 950) which has an apparently rare 34 pin Half Screen LCD (most are 26 pin I'm told). Do you know where I can get one of these? Or if the unit 8DO 920 950LX would have the same 34 pin half screen as mine so I could buy it and use the screen. I have a late 1999 1.9tdi and I'm told that the LX cluster is for a 1.6 Petrol 2000 > 2001. If I can't get a new screen is there any way that I can get a different instrument cluster to work in my car? My Wiper Stalk does not have any reset buttons etc on it but I could obviously change that if need be. Hope you can help me with this. Should mention I am in the UK with a UK car and my problem is that the LCD screen doesn't work. If the 8DO 920 950LX one is compatible could I just fit that and get my the mileage set? Would be really grateful if you can help me on this.
#106
Hi,
I have a question:
I put in the main instrument cluster (no oil temperature and voltmeter) to replace the oil temperature and voltmeter version?
Or required extra cabling?
Currently:
New:
I have a question:
Currently:
New:
#108
first test the cluster in your vehicle and see if the voltmeter and oil temperature will work, your vehicle might be pre-wired for this option,
#109
Doug
Doug
#110
Who is manufacture of your cluster Bosch VDO or magneti marelli ?
When you are looking for another cluster with the half/screen LCD you need to buy the same manufacture cluster to get the same LCD
