Vibration
Old Apr 19, 2005 | 05:21 AM
Setzer's Avatar
New Member
Default Vibration
Will bad Conrtol Arms cause the car to vibrate when you break traction, I have a FWD V6 and it has not T/C by the looks of it and its wet here where I am at the moment, whenever the wheels break traction the whole car goes into a skitso vibration eminating from the front of the car obviosly.
If so Could this mean upper or lower arms, or is it to hard to tell?
Your input would be awesome thanks.
Old Apr 19, 2005 | 05:27 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Vibrator.
your car does likely have EDL, which would cause the ABS to pulse the front wheels to try to force the diff to redirect the power to the other side.. That's probably what you are feeling.
Old Apr 19, 2005 | 05:29 AM
imok's Avatar
Default hu.....
bad ball joints cause vibration, bad rotors caused it too when breaking. in some occasions it causes the car to pull too. check both
Old Apr 19, 2005 | 05:35 AM
Setzer's Avatar
New Member
Default Re: Vibrator.
Thanks for they reply
But...
It didnt seem to do it before tho its only just started happening.
Has anyone else had this prob with a Front Wheel Drive? I get a little suspension knock so Im thinking it is my control arms, but i dont know whether it is causing this or not
Could it be an engine or tranny mount, and if so how do you check those ? Visually ?
If someone could please reply it would be awesome, i know i sound like a scab but if i manage to find the problem ill do a writeup for an F.A.Q. or something.
Old Apr 19, 2005 | 05:37 AM
DON2.0T's Avatar
an broken driveshaft causes vibration
Old Apr 19, 2005 | 05:38 AM
Setzer's Avatar
New Member
Default Re: hu.....
Can ball joints make a little knocking noise when going over bumps and uneaven surfaces, *can only be heard at low speeds.
Old Apr 19, 2005 | 05:39 AM
Setzer's Avatar
New Member
Default Re: an broken driveshaft causes vibration
Its not quatro.
Dose the FWD have a driveshaft?
Old Apr 19, 2005 | 05:44 AM
ScarfaceNostra's Avatar
Default How old are your tires?
I know someone with a similar problem, and he actually needed new tires... vibration was bad too...
Old Apr 19, 2005 | 05:46 AM
Speedy72t's Avatar
if it isn't EDL I'd go to the engine/trans mounts next
Old Apr 19, 2005 | 05:50 AM
Setzer's Avatar
New Member
Default Re: How old are your tires?
Brand new, that was my first idea.
