Weird smell when idle in neutral at stop.
Don't know which transmission is in your car, but electromechnical transmissions can be wet or dry clutch. If you have a dual clutch and they are dry clutches...it is possible that one/both are not properly disengaging when you shift to neutral, resulting in yes, a burning clutch smell. Normally in any electromechnical transmission, touching the brake pedal, dropping to zero mph and minimum rpm, etc. tell the transmission to release the clutches. And if they don't disengage...burned clutch, and smell. If you are under warranty, "Takee Fixee". If you are not...still needs to be looked into.
You've got a sharp noise if you're able to be sure it is clutch smell!
Could it be oil leaking onto hot components? This is frequent for these cars if you have not done the usual gaskets and such for an Audi this age.
Sloooo4esT
Audi Original "S" Cars
09-24-2007 08:23 PM
s4florida
10-13-2004 08:16 PM
Dustin A4
12-19-2001 08:46 AM
myfirstimport
02-27-2001 08:49 AM
