A8 Upgrade: is it a lot of improvement over stock? I know big brake kit is the ultimate....
Old 10-15-2003, 07:27 AM
BSCA4's Avatar
Default A8 Upgrade: is it a lot of improvement over stock? I know big brake kit is the ultimate....
but I do not have that much money to spend. TIA
Old 10-15-2003, 07:30 AM
AudiWorld Expert
CraigB's Avatar
Default It's a worthwhile upgrade...
The A4 owners I've known with the A8 upgrade are very pleased with the results. I upgraded to TT rotors (same size as A8) on my GTI and it makes a huge difference on that car.
Member
SCd_Walter's Avatar
Default it's the ultimate in simplicity
I installed the A8s in less than 45 minutes from start to finish last night.
Haven't gotten on them to test them yet, but they look cool =P
Old 10-15-2003, 07:32 AM
Elder Member
Reggie3's Avatar
Default I think that it removes the wet braking issue and will allow you to track your car
meaning it will consistantly stop even when the brakes are hot with out warping the rotors and destroying the pistons in the calipers.
But I doubt it will stop your car any faster. It also adds lots of undamped weight.
Check with Colorado Mark - he did it to his car (posts on Rocky Mtn forum.)
Old 10-15-2003, 07:38 AM
rickw's Avatar
Unfortunately, it did not fix wet braking for me.
Old 10-15-2003, 07:40 AM
Member
jprice@CPS's Avatar
Default Getting the caliper out further give you more leverage...
and the larger rotor should dissapate heat a litte better. You may also want to look at getting stainless steel lines and upgrading the brake fluid also.. if you plan on tracking the car.
Old 10-15-2003, 07:51 AM
AudiWorld Expert
ex-quattro PETE's Avatar
Default having driven an A4 with the A8 upgrade (and high-perf. brake fluid)...
I can say that it is a pretty big improvement over stock. When my rotors are ready to go, I'll be doing this upgrade myself.
Old 10-15-2003, 08:04 AM
Elder Member
Blake(w/ 16g)'s Avatar
Default huge braking improvement, even with stock brake fluid,
the wet braking issue was resolved with my setup, although i bought slotted rotors for both the A8 front setup, and the stock rears...
SGH
04-11-2009 03:45 PM
BSK auf Arbeit
06-26-2005 06:49 PM
SUBLIME
06-24-2005 07:07 AM
BSK auf Arbeit
04-27-2005 05:10 AM
DannyA4
05-23-2002 07:58 AM
Quick Reply: A8 Upgrade: is it a lot of improvement over stock? I know big brake kit is the ultimate....
