What triggers the electric aux fan in the engine bay to come on?
ever since I replaced my turbo the aux fan will come on with the ignition and runs constantly. disconnecting it from the AC system does disable the fan. ideas on troubleshooting?
a short to ground on the A/C pressure switch or a short to ground on the coolant temp thermoswitch
hmmm... I did replace the original coolant temp sensor in the lower rad hose w/ the turbo...
I'll start there... thanks for the heads up!
good luck!
