Yakima Bike Rack for the A4?
#14
Guest
Posts: n/a
Why I would choose Yakima...
I had a Thule on my old car - I used to leave it on almost all the time. The rack uses screws to tighten the clamps onto the car. These screws oxidized and made it impossible for me to remove the rack from the car.
Although the newer Thule design uses some sort of swing arm - the adjustment is still accomplished by the same threaded screw. I don't look forward to it oxidizing on me.
I went to a professional rack place that was able to outline exactly what Yakima parts I required (they had them all in stock too). The Yakima rack does not use a threaded screw of any sort and I suspect will stand up to the weather just fine.
NOTE: Canadian suggested retail prices for Yakima stuff is almost identical to the US!! You US guys will save if you buy up here due to your favourable currency conversion (save 30%?)
My .02...
Gordon Martin
98.5 2.8QMS
My .02...
Gordon Martin
98.5 2.8QMS
#15
Guest
Posts: n/a
My way avoids scuff marks....
I use a very thin strip of static-cling window tint on the roof just under the spot the fairing would make contact with the car. It completely seals out water, dust, and dirt. You can't see it and you can place the fairing is any position you want.
I also use a rectangular piece of tint under each footpad of the rails. I've mentioned this idea several times before.
Doesn't anyone use it? I think it works great.
Drew
Drew
thinkpad
11
08-23-2002 05:12 AM
I.H.A. (it hauls @#%)
11-08-2000 09:03 AM
