CenTexA4 |
11-29-2004 08:25 AM |
02 3.0 Quattro Sport w/Tip: Transmission TSB issue
I took my car in for routine service and they loaded a new program into the tiptronic transmission computer to fix some issue. I like to keep the transmission in sport mode for better response because in normal mode the 2-3 shift is like dropping an anchor. Previous to the "fix", the transmission would shift into 5th gear around 55-65mph in sport mode. After the "fix", I've taken it up to 80 mph, and it won't shift into 5th in sport mode. The service advisor thought it was broken when I took it back in and said he'd research. Now he says that he contacted a ZF transmission engineer in Auburn Hills, MI and was told that is how it is supposed to behave, that it was broken before the fix. It doesn't seem right that the car should be cruising at 4K+ rpm in 4th gear at 80mph when not accelerating. Now I have to shift from Sport to Drive once I'm cruising at highway speed to get into 5th gear. Can anyone verify this behaviour as normal? I sure wish I had gotten the manual transmission, this slushbox is a dog!
