1.8 timing belt install question
I have new belt, tensioner, belt, water pump ect. installed. Reference marks on cam sprocket and crank sprocket (made with sharpie before disassembly) look good.
Now I'm rotating crank by hand to confirm timing before buttoning everything back up, #1 plug still out with a long extension inn to confirm tdc.
Here's the thing that concerns me.
at 2 points during the cycle there is a slight pop sound from the #1 spark plug hole accompanied by a slight jerk. So now I'm second guessing myself. Is this just the valves working and change in compression or am I getting slight interference?
I'd probably remove the other plugs so there is no compression. Also, depending on the cam lobes positions, whenever going past center (valves fully open) the spring forces will give a push on the cam. This might cause a click of chain slack for instance, but from #1 cylinder it should be quiet. I guess you could pull the valve cover to verify what's happening.
I'm of relatively advanced ability, but am also very deliberate. It took me better part of a day or about 4 to 6 hours. Most of it is about locating the connecting bolts which aren't easy to find even with a guide.
