Changed O2 Sensor Twice, Still Throwing Codes
Old 04-26-2011, 09:23 AM
gerisilo's Avatar
Default Changed O2 Sensor Twice, Still Throwing Codes
I have a A4 3.0L and I have replaced the driver side pre cat O2 sensor twice within a couple months of each other, with OEM O2 sensors, and each time I am still getting a slow response code for that sensor.
I took it to a shop for diagnostics and they ran each O2 sensor to get their exact readings, and they said they all start up fine, but the driver side pre cat sensor gradually gets slower and slower. They were stumped and not sure what the reason might be.
The car is still running fine, not idling rough or running rich, but the CEL is eternally on. Thinking about selling the Audi too, so it would be nice to have the CEL off.
Any thoughts? Would be awesome to figure this out once and for all.
Old 04-26-2011, 03:15 PM
turbo510's Avatar
I would wonder about the cat on that side, if somewhat clogged might slow the exhaust flow. Maybe a few good full-throttle runs up a long hill would help. How does it run otherwise?
Old 05-02-2011, 05:55 PM
NYC_S's Avatar
Hi, did you replace the sensor yourself? What was your trick on getting it out. If you brought it to the shop, how much did they charge you for it.
Old 05-04-2011, 01:24 PM
gerisilo's Avatar
I wondered about the cat as well, but the shop said that would be throwing a separate code, especially since the sensors are so sensitive.
I did change it myself. Just used an O2 sensor socket and a long extension to a ratchet. It's kinda awkward but easy enought to do. The shops usually want to charge 3.5 hours of labor. It took me maybe 30 minutes. Just make sure the engine is completely cool, it's a lot easier if you can get your hands in and around there without burning the crap out of yourself.
tailorisellis
A4 (B7 Platform) Discussion
04-22-2018 04:32 PM
mattd860
02-21-2005 05:59 PM
theodore
02-04-2005 02:47 PM
mmart6545
01-26-2004 05:09 AM
Quick Reply: Changed O2 Sensor Twice, Still Throwing Codes
