A4 misfiring, shaking... fuel filter??HELP!
A couple of weeks ago my engine in my 2002 Audi A4 1.8T started shaking and check engine light flashing. Took it in code read for misfire in ignition coil for cylinder one, so I replaced it. I should have known due to how easy it was. Sure enough, yesterday it happened again, took it in again and now have codes: P0300, P0301, P0303, P0304 and I think P1296 (I remember it was for the CST)/ I replaced all coils, sparkplugs and CST..which the CST is a MAJOR pain but I managed. It's still shaking w/ a flashing check engine.. could it be the fuel filter and if so,,, how the heck do you change the fuel filter on this thing?
Thank you!! |
My apoligies, I meant the CTS - Coolant Temp Sensor.. thanks.
Good Morning, If it is in fact your Fuel Filter, here is the DIY:
http://www.audizine.com/forum/showthread.php?t=224783 If it's your fuel pump here is that DIY: http://www.a4mods.com/index.php?page...tml&category=5 Either way, good luck. I am sure there will be other members to let you know or help you diagnose the problem if it isnt either one of these items. |
Audigrll27, also after the new CP and the CTS replacement, did you clear the codes? sometimes It does take a few days for the ECU to clear itself and return to normal. Might want to clear the codes and give it a few days to adjust itself. :)
My car is doing the same thing -- shaking and "check engine" light flashing. The dealer tells me it's the coils (3 out of 4 are bad) and will cost $450 to replace. Does this cost estimate sound right? Am I getting ripped off?
Originally Posted by aharris
(Post 23833223)
Originally Posted by corvettekiller18
(Post 23833233)
YES, you are getting ripped off. Ignition coils should b about $30-40 each. at most thats 120$ for 3 of em, and it takes about a minute to swap each coil with a new one! Very easy job.
I should've known better than to go to the dealer, but I was in a bind and my car was shaking and the check engine light was flashing, so I got nervous and went straight there. |
Originally Posted by Audigrl27
(Post 23789326)
Thank you!! |
A4 Misfire
I have 03 Avant with less than 50 KM..Currently on 3rd set of coils. 2 sets were replaced under warrenty.
Always ask for the old good coils back if dealer replaces all 4 I keep a few in the trunk and have had to do roadside hotswap a couple of times. I also notices that coil # 4 (closest to rear of engine) the coil wire harness was chafing against the cyl head and was shorting when engine got really hot (sitting in traffic)All you need is a flathead screwdriver to remove plastic engine cover Wrap a bunch of electrical tape around wires where they are near cyl head. |
(Post 23833249)
Thanks for the quick response. The breakdown was $51.07 per coil (x4), $16.53 per plug (x4), and $160 labor.
