b6 a4 locks and windows coding question
Old Oct 12, 2005 | 04:27 PM
specialidiot's Avatar
Default b6 a4 locks and windows coding question
Cross posted from the VAG forum:
I'd like to set my locks to engage when underway, and add the window up/down from the key fob.
what do I set my coding to?
here are my settings:
Address 46: Central Conv.
Controller: 8E0 959 433 BB
Component: Komfortger?t T7B 1311
Coding: 11788
Shop #: WSC 63251
Old Oct 12, 2005 | 05:34 PM
needforsleep's Avatar
Default here...
You have to flip a bits 5 &amp; 6.<ul><li><a href="http://www.ross-tech.com/vag-com/cars/audiB6.html">http://www.ross-tech.com/vag-com/cars/audiB6.html</a></li></ul>
Old Oct 12, 2005 | 06:11 PM
Default sorry, I'm a hardware guy
given my current coding is 11788, what do I use to get the locks to auto engage and the windows to go up/down with the switch.
Thanks....
Old Oct 12, 2005 | 06:18 PM
Default oh, sorry...(info at bottom)
Central Convenience Controller Coding:
State Bit Dec. Function
OFF 0 1 Great Britain- alarm system (only with bit 4)
OFF 1 2 flash on when arming/unarming alarm system
ON 2 4 selective locking 1 door/all doors
ON 3 8 activate alarm system
OFF 4 16 rear unlocking block via speed
OFF 5 32 locking via speed
OFF 6 64 comfort functions with remote (adapt in ch 62!!)
OFF 7 128 right side steering
OFF 8 256 avant (glass break sensors in rear side-and rear
windows (if error: safe-LED constantly lit ))
ON 9 512 1x flash when lock with remote
ON 10 1024 horn sounds when lock with remote
ON 11 2048 door/window-logic ( ignition off: No open door
el. windows works 10 min )
OFF 12 4096 normal/????-alarm system
ON 13 8192 No SAFE-function USA only
OFF 14 16384 insulate-glass PR-nr 4KR/4KV
To flip those bits, you need to add 32 and 64 decimal to the controller coding.
Thus: 11788 + 32 + 64 = 11884
Old Oct 12, 2005 | 06:32 PM
thank you!!!! (heads down to garage....)
Old Oct 12, 2005 | 06:43 PM
Default works like a champ
didn't try the "speed locks" tho....
I appreciate the help!
Old Oct 12, 2005 | 07:05 PM
Default no problem...
you can also turn on the feature that unlocks all the doors with one press of the key fob.
Old Oct 12, 2005 | 07:12 PM
so, add 4 more? = 11888?
Old Oct 13, 2005 | 03:46 AM
no, this one you are disabling the "selective locking" so you need to delete 4...11880
Old Oct 14, 2005 | 06:52 PM
got it, thank you
IntheQ5
Q5/SQ5 MKI (8R) Discussion
38
Oct 21, 2024 10:43 PM
carl viking
40
Jul 12, 2024 02:45 PM
CPLYONS
Sep 3, 2015 07:04 PM
Sandito8e
New Member Welcome Area
Sep 2, 2015 08:47 PM
stormchaser1967
Sep 2, 2015 09:02 AM
