back of drivers seat...
the plastic backing of my drivers seat (where the net pouch is keeps popping out when i sit..i can push it back into place but it keeps popping out...from the bottom to about half way up the seat pops out...any fixes?
There is a kit you can buy from Audi to fix this.....
I have the same problem,, just haven't gotten around to picking up the kit. Its about $20. or so.
Re: back of drivers seat...
THAT MIGHT BE BECAUSE YOUR LUMBAR SUPPORT IS BROKEN, PULL THE COVER OFF AND YOU SHOULD SEE LIKE A METAL GRID, IF YOU CAN WIGGLE IT FREE ON ONE SIDE THAN IT'S BROKEN AND NO MATTER HOW MANY TIMES YOU RESECURE THAT BACK PIECE IT WILL COME LOOSE.
if the bottom mounts are broken, its about $250 to replace, i just bought one
He speaks the truth
My car had the same problem, the lumbar broke and then the seatback tabs broke when there was pressure from me (well, the previous owner) sitting in it.
I replaced the lumbar support but gravity and motion still pop out the back. Im thinking of just using a small countersunk metal screw on each corner to hold it down. Painted black, of course. |
can you elaborate? PN? have any pics or links?
I was going to use screws, but if there is a $20 fix that doesnt show on the outside then I'll get that instead.
Thanks! |
The kit to repair the lower seat back is 8E0-898-035
