Window won't go up, not sure what's wrong
I have a 2004 A4 3.0L Quattro, and the driver's side window appears broken now. When I went to roll it up, it felt different and wasn't smooth, then later on it wouldn't go up all the way, so i rolled it down a little and then up, and then it would go up.
Now I just came home and had the window down and it won't roll up at all. It did make a clunking sound a few times when it wasn't going up and down properly. When I get into the car and put the key in and try to roll it up, i hear the 'electronics' trying to activate it, then nothing. Then if I try again, i don't hear any sounds.
Any idea what it could be?
Also, is there a way to roll up the window manually?
Your window regulator is shot, very common for Audi's... The good news is that it is not too hard to fix, you just have to take the door molding off (make sure you find all the screws before you start yanking on it). In the mean time if you can expose a little of the window, pull it upward and have someone pull the up button at the same time until it is closed. Here is the part you need to order...
http://www.ecstuning.com/Audi-B6_A4-...dow/ES2500598/
Good luck, I've been through this 3 times now.
Also, any particular brand I should buy? I read that the OEM version has some cheap plastic part that keeps breaking, but PIMAX has some metal parts instead of the cheap plastic part. Anyone recommend any good brands that will last?
Thanks again.
When this has happened to me, the cable was either stretched and twisted or the pulley wheel broke and the cable jumped off. There isn't a doubt in my mind that yours is shot and they are not serviceable, you just have to get a new one. The B6's aren't riveted in like the B5's so it is a much easier job. I'm not sure about the metal vs plastic part you mentioned but for me it has always been a pulley or cable. The cable binding is the noise that your hearing. My $.02, just get the cheapest replacement you can, it will last just as long as your current one did.
Window broken AGAIN!
So I had the window regulator replaced at an Audi Independent place about 3 weeks ago. Today, it's broken again. It was stuck at the half-way point and when i was pushing the window button up or down it made this crunching noise. I managed to have my brother pull up window while I was pulling up on the lever/button.
I pushed down on it just a little and the window went down about 4 inches while making the crunching noise (sounds like crunching up a thick plastic bag), and then tried to roll it up again. Just kept hearing the crunching noise and it sounded like something was getting more and more tangled. Well we coudln't pull it up again and now when i push up or down on the window button, there's NO noise at all (not even a 'trying' noise). Could I have broken the motor in the process, or is window regulator cable just so twisted it won't even budge. I hope I didn't break the motor Please let me know. Thanks.
If not the regulator then could be the window master switch http://switchdoctor.net 30 day return policy.
what was the part that was broken ?
Is there a way I can know if it's the window regulator for sure and what part of it is broken?
Thanks again.
Thanks again.
what is the part i need to buy? the link doesn't work for me.
Could be the regulator, could be the motor, could be the switch. Have you troubleshoot it yet? When you activate the switch is there any noise? Can you manually pull the window up?
