A bucket load of faults... Any ideas??
Hi,
I did a VCDS Scan on a mates car this afternoon and was astonished at the number of faults found...
Anyone have any idea if there are any of these faults interconnected, hence the massive number found??
I cleared all of them, then did a rescan it and this is what showed up...
Any idea what causes these faults??
TIA FF.
its a 2006 Audi A4 2.0 Tdi saloon.
Thursday,02,May,2019,22:48:05:12984
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64)
Data version: 20190114 DS296.0
Ross-Tech: Home
VIN: WAUZZZ8EX5A477812 License Plate: XX56 UCY
Mileage: 297290km-184727mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8EX5A477812 Mileage: 297290km-184727miles
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00561 210 91516
VCID: 75E1912A1CF38EE2FE-8020
2 Faults Found:
17996 - Engine Mount Solenoid Valves (N144/N145)
P1588 - 000 - Open Circuit
Freeze Frame:
RPM: 1008 /min
Torque: 22.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00101100
Torque: 158.6 Nm
Torque: 0.0 Nm
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2100 /min
Torque: 166.0 Nm
Speed: 104.0 km/h
Load: 42.4 %
Voltage: 14.44 V
Bin. Bits: 00101000
Absolute Pres.: 1897.2 mbar
Absolute Pres.: 1366.8 mbar
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06335 000 00000
VCID: 2643866691D5B57A87-8072
1 Fault Found:
00526 - Brake Light Switch (F)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 87
Reset counter: 39
Time Indication: 0
Freeze Frame:
Hex Value: 0x07C0
Hex Value: 0x4006
Hex Value: 0x00FF
Hex Value: 0xFFAF
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AJ
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 69D9CD5A134B5A026A-5124
2 Faults Found:
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
09-00 - Adaptation Limit Surpassed
01331 - Door Control Module; Driver Side (J386)
49-10 - No Communications - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 H
Component: int. Lastmodul ECE 0303
Coding: 00001
Shop #: WSC 06335
VCID: 377D5B22157F3CF22C-4AE8
5 Faults Found:
00979 - Lamp for Low Beam; Right (M31)
30-00 - Open or Short to Plus
01518 - Bulb for Back-Up Lights; Left (M16)
01519 - Bulb for Back-Up Lights; Right (M17)
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M0022A24
Coding: 0033622
VCID: 3B7547127A571892C8-806E
Subsystem 1 - Serial number: 6332DRB4015305164
Subsystem 2 - Serial number: 6342DRB40152D1B0H
Subsystem 3 - Serial number: 6352ARB4004597EEZ
Subsystem 4 - Serial number: 6362ARB400435B39I
Subsystem 5 - Serial number: 63729RB40046A478M
Subsystem 6 - Serial number: 63829RB400469BA3R
2 Faults Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 99
Time Indication: 0
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 254
Reset counter: 99
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 01021
Shop #: WSC 06335
VCID: 418935FA4BBB724292-4B00
1 Fault Found:
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 950 S HW: 8E0 920 950 S
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006441
Shop #: WSC 00409 210 91061
VCID: 39795D1A736B2A82DA-5124
1 Fault Found:
004 - No Signal/Communication - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006441
VCID: 39795D1A736B2A82DA-5140
1 Fault Found:
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 06907
Shop #: WSC 06335
VCID: 7DF1890A77C3D6A2B6-4AE8
Subsystem 1 - Part No: Steuerger
Component: t Fahr. antwortet nicht
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
7 Faults Found:
49-00 - No Communications
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01001
Shop #: WSC 06335
VCID: 285F885EC8C1A30AB5-4B00
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
36-00 - Open Circuit
End-------------------------(Elapsed Time: 06:32)--------------------------
TIA FF.
Ross-Tech: Home
67 69 75 76 77
Coding: 0000072
2 Faults Found:
Freeze Frame:
RPM: 1008 /min
Torque: 22.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00101100
Torque: 158.6 Nm
Torque: 0.0 Nm
Freeze Frame:
RPM: 2100 /min
Torque: 166.0 Nm
Speed: 104.0 km/h
Load: 42.4 %
Voltage: 14.44 V
Bin. Bits: 00101000
Coding: 0004401
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 87
Reset counter: 39
Time Indication: 0
Freeze Frame:
Hex Value: 0x07C0
Hex Value: 0x4006
Hex Value: 0x00FF
Hex Value: 0xFFAF
Hex Value: 0x00FF
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
Coding: 00001
Shop #: WSC 06335
5 Faults Found:
Coding: 0033622
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Reset counter: 99
Time Indication: 0
Coding: 01021
Shop #: WSC 06335
1 Fault Found:
Coding: 0006441
1 Fault Found:
Coding: 0006441
1 Fault Found:
Coding: 06907
Shop #: WSC 06335
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 01001
Shop #: WSC 06335
1 Fault Found:
I didn't read thru your information, but try to look at the dates of the faults BEFORE YOU DELETE THEM!! The cars keep track of the last time a fault was reported.
A bad/weak battery can cause all sorts of interesting problems with these cars. Phantom faults are often generated.
The mass CLEAR DTCs option typically does NOT clear all the faults. I've gotten into the habit of going into each troubled module and clear them one by one.
