Calling Bob Petruska, please check your e-mail.
Don't see the email, but your past post stated the headlight washer pump, not piston.
I said you can remove the headlight washer pump without removing the front bumper. You remove the driver's side front inner wheelwell liner, remove the washer fluid resevoir to get at the headlight washer pump.
Now if the the headlight washer(piston) needs to be replaced them I'm sorry to say that the front bumper needs to come off. I had a leaky washer that was bleeding a quart or two of washer fluid a day. I definitely didn't want my dealer removing my Brillant Black bumper as it would never be the same with all the scratches and gouges they most likely would have inflected. I just disconnected the electrical connector for the headlight washer pump, pulled the headlight washer hose and plugged the washer pump outlet. I really don't need the headlight washers at all, they just consume too much fluid when not needed. I need the fluid for my windshield and would run out quite fast at night with the headlight washers constantly squirting with all the slush and salt in northeastern winters.
Hope this helps.
Hope this helps.
Bob...thanks...it is the connector to the piston that they say they cannot reconnect without
replacing the whole unit with the connector attached from the factory. I am also concerned about removeing the bumper, not to mention scratches, but breaking factory seals, getting rattles, etc... My car like yours was dumping the fluid as fast as I can fill it, but I didn't see the leak until the car was on a slight incline one day. I am completely amazed that this could happen on a brand new car. Had to be a factory defect because my fluid low light came on the day I drove it off the lot. I greatly appreciate your advice.
PS: sent the email to your microserve.net address, don't want to put it here, but it is out there on Audiworld
carl viking
36
04-27-2020 01:17 PM
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
the_duke
09-10-2015 09:02 AM
