Can someone scan and tell me what the Airbag coding is on the airbag control module...??
This is found by scanning the air bag control module via vag com and clicking the coding / recode button. TIA for the help!
Lookee here-
Clicky-<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_A4/S4/RS4/Cabriolet_(8E/8H)">http://wiki.ross-tech.com/index.php/Audi_A4/S4/RS4/Cabriolet_(8E/8H)</a</li></ul>
What is the PN for the Air Bag Controller?
The VAG COM lable file includes coding and adaptations. For the Airbag controller version 8.4, PN 8E0-959-655, the coding: "0010702" - Series + rear side airbags.
Here is the text lable file:
; VAG-COM label file
; Audi A4 (8E2/8E5)
; component: J234 - Airbag 8.4 (#15)
; p/n: 8E0-959-655-???
; includes measuring blocks, adaptation and coding
; This file is part of a redirection package,
; make sure you have all of the following files.
; 8E-15.LBL
; 8E0-959-655-84.LBL (Airbag 8.4)
; 8E0-959-655-94.LBL (Airbag 9.4x)
; created on 27/Sep/2004 by Sebastian Stange (sebastian@ross-tech.com)
; last modification: 25/Aug/2005
; requires VAG-COM 405.0 or newer
; measuring block information
001,1,Drivers-side,airbag,Display range: correct/too low/too high/endp. GND/endp. B+
001,2,Passenge-side,airbag,Display range: correct/too low/too high/endp. GND/endp. B+
001,3,belt tensioner,driver-side,Display range: correct/too low/too high/endp. GND/endp. B+
001,4,belt tensioner,passenger-side,Display range: correct/too low/too high/endp. GND/endp. B+
002,1,belt tensioner,driver-side rear,Display range: correct/too low/too high/endp. GND/endp. B+
002,2,belt tensioner,passenger-side rear,Display range: correct/too low/too high/endp. GND/endp. B+
002,3,belt tensioner,center rear,Display range: correct/too low/too high/endp. GND/endp. B+
003,1,voltage supply,Display range: correct/too low
003,3,seatbelt switch,driver-side,Display range: too low/too high/endp. GND/endp. B+/n.defined/belt YES/belt NO
003,4,seatbelt switch,passenger-side,Display range: too low/too high/endp. GND/endp. B+/n.defined/belt YES/belt NO
004,0,Belt usage recognition
004,1,driver-side,rear,Display range: too low/too high/endp. GND/endp. B+/n.defined/belt YES/belt NO
004,2,passenger-side,rear,Display range: too low/too high/endp. GND/endp. B+/n.defined/belt YES/belt NO
004,3,center,rear,Display range: too low/too high/endp. GND/endp. B+/n.defined/belt YES/belt NO
006,0,Igniter for side airbag
006,1,driver-side,front,Display range: correct/too low/too high/endp. GND/endp. B+
006,2,passenger-side,front,Display range: correct/too low/too high/endp. GND/endp. B+
006,3,driver-side,rear,Display range: correct/too low/too high/endp. GND/endp. B+
006,4,passenger-side,rear,Display range: correct/too low/too high/endp. GND/endp. B+
008,0,Igniter for head-level airbag
008,3,driver-side,,Display ange: correct/too low/too high/endp. GND/endp. B+
008,4,passenger-side,,Display range: correct/too low/too high/endp. GND/endp. B+
; coding information
C0,Airbag (J234) Coding
C1,Rest of world (Series: Front airbag, side airbag front, seat belt tensioner front, head airbag)
C2,0010602 - Series
C3
C4,0011602 - Series + key switch to deactivate passenger airbag
C5,0011702 - Series + rear side airbags + key switch to deactivate passenger airbag
C6,
C7,USA and Mexico (Series: Front airbag, front side airbags, front seat belt tensioners, head airbag)
C8,0010605 - Series with 2 rear seat belt tensioners
C9,0010705 - Series with 2 rear seat belt tensioners + rear side airbags
C10,0010607 - Series with 3 rear seat belt tensioners
C11,0010702 - Series with 3 rear seat belt tensioner + rear side airbags
; adaptation information
A81,0,Learned Values (Vehicle Data)
A81,5,Learned Values (Vehicle Data)
A81,6,To start the process for vehicle data (VIN)
A81,7,learning enter/save 02905 as new value.
end
; Audi A4 (8E2/8E5)
; 8E-15.LBL
C2,0010602 - Series
C3
C6,
end
Aman Singh Parhar
11-29-2016 05:03 AM
Cmmartin23
26
08-23-2016 04:44 PM
saifxnyc
9
11-30-2015 12:32 PM
ajg617
09-06-2015 07:23 AM
