Check Engine Light - Code P1128 - "Bank1 Lean" - HELP
Recently I started getting this code - P1128 ,
Long term trim mult bank1 lean. Has anyone fixed this and know what it is. Apparently it could be oxygen sensor, vacuum, etc. I am afraid this could be a fortune in parts and labor to fix.....
Thanks ahead of time.
David
David
I had a similar thing
i had a similar thing. Firstly I assume 'check engine light' you mean the little red picture of the block - I don't know the codes but my car (A4 3.0)thought it was running lean.
The dealers / roadside guys checked:
The coil packs - changed lots of them.
Checked any and all sensors.
Loaded new software.
Checked the exhaust wasn't sucking clean air in through a leak or crack - therefore giving a false lean reading.
Finally mine was damaged fuels lines (previous owner incident) effecting the fuel pressure. the fuels lines are covered by long black plastic covers on the underside.
Good luck.
Good luck.
Re: Where were the leaks: Check Engine Light - Code P1128 - "Bank1 Lean" - HELP
two vaccuum hoses, one easily visible the ohter way down under, used smoke system at buddy's shop to find them, fixed for about $26 in parts
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
