Fault Codes Help !!!!
Old Jan 19, 2016 | 07:48 AM
NICKIE's Avatar
Default Fault Codes Help !!!!
I have a 2003 Audi A4 1.8 T Quattro
Pull into drive way CEL light was flashing , car had a miss fire . As all German cars I went to the coil packs. Scan codes and getting PO688
ECM/TCM power relay sense circuit . I got another ECM , plug into car and getting same fault code . The engine cranks over, checked and I have fuel pressure . Audi still wont crank . Any ideas or help would be help full.
Also this happen all at once , not a ongoing problem that I ignored .
Old Jan 20, 2016 | 04:05 AM
lyleswk's Avatar
The fault code indicates more of a power issue to the ECM, not the ECM. I am helpless on power issues, but here is the ross tech troubleshooting guide. Need to do some research on the "relay 271".
17072/P0688/001672 - Ross-Tech Wiki
Old Jan 24, 2016 | 05:22 PM
roger Garcia's Avatar
Hey I had a similar problem on a4 what I found on my car was that fuel injector connectors wiring were in bad shape .I replaced them and no more misfire. U might want to check your connection wires
rickyjlucas
Jul 7, 2016 05:49 AM
Ossy1020
2.7T V6 Discussion
Apr 30, 2015 09:08 AM
xryanx23
Jul 20, 2012 12:16 PM
Fastscirocco
Audi Original "S" Cars
Feb 20, 2008 11:59 AM
jihax
12v V6 Discussion
Oct 15, 2006 08:04 PM
