Fuel Gauge and Computer Problem
Hey everyone -
Last month I took my car to have it's fuel filter and fuel pump replaced. The next time I added fuel I noticed the fuel needle hardly moved. As this had never happened before, I actually went back to the gas station to let them know their pump wasn't delivering the correct amount of fuel! Today, with 10 mile to empty, I added six gallons (at a different station) and the needle still hasn't moved - in fact it now shows 0 MTE. So it looks as if while replacing the fuel pump and filter, they screwed something up. Or is this just an amazing coincidence? Thanks for any help you can give me. |
I had this happen pull the fuel pump fuse and the instrument cluster fuse turn on (not engine just electronics). Turn off put fuses back it will reset it's self.
Originally Posted by SilasJudd
(Post 23823154)
I did just what this says, pull fuse 15 & 28, turn ignition or try to start the car (wont start because no fuel pump...), then put fuses back and good as new...!!! My fuel gauge has always been perfect. Then last night out of nowhere it was broken. I got gas and filled the car up, yet it still said 10 miles till empty. Then over the next 20 miles it dropped to zero. I even went and got more gas thinking that I was crazy because this had never happened before. But not the fuel gauge is working, the sensor unit is presumably fine and it took 10 minutes of searching to find this one post, and 1 minute to pull fuses and fix. Awesome! |
Problem Solved
Originally Posted by pjp13
(Post 24002983)
Thanks a million, I thought I was going to have to pull my sensor out of the tank....
I did just what this says, pull fuse 15 & 28, turn ignition or try to start the car (wont start because no fuel pump...), then put fuses back and good as new...!!! My fuel gauge has always been perfect. Then last night out of nowhere it was broken. I got gas and filled the car up, yet it still said 10 miles till empty. Then over the next 20 miles it dropped to zero. I even went and got more gas thinking that I was crazy because this had never happened before. But not the fuel gauge is working, the sensor unit is presumably fine and it took 10 minutes of searching to find this one post, and 1 minute to pull fuses and fix. Awesome! This worked! Thanks for the info. solved the problem in 2 minutes!! |
1 Attachment(s)
I did just what this says, pull fuse 15 & 28, turn ignition or try to start the car (wont start because no fuel pump...), then put fuses back and good as new...!!! |
Originally Posted by mistrb
(Post 24171506)
Wow, my car doesn't have any fuses in positions 15 & 28. What can I do?
fuel gauge stays on full
hi all im a new audi owner and have simular problem with fuel gauge it was showing empty so proceeded by taking out fuses and turning ign on then off and re-fitting tho now fuel gauge says full all the time.....any ideas.
many thanks jase. |
Hello,
Just want to thank you. I bought Audi A4 B6 with the same problem with fuel gauge. In service told to change instrument cluster. And than I found this tread and I fixed by my self in 5min. So many thanks and greetings from Lithuania, Jurbarkas. |
Me too
(Post 24171506)
I'll keep you guys posted. BTW: the gauge was working until Sunday when i was driving back to Czech from Slovakia. It showed half a tank then it went to empty and the light came on.. I'll say it was pretty stressful driving back with the LOW GAS light on. |
nope!
Originally Posted by Xander2727
(Post 24455731)
I've got the same problem as the post, and i think I'm missing fuses in those locations too.. i haven't checked yet. i will later today, but i'm in Europe and my manual is in German.. any ideas on how to get an English version of the manual?
