Heater problem
Reason I ask is I have an 02 with 197K and it's heater core was clogged. This is typically the issue. I attempted to replace mine this weekend and failed to get the clamps back on the aluminum lines and new core (car was towed sans coolant to my favorite indie this morning), but when I poured water backwards through the old core, lots and lots of small sediment came out and continued to come out until I got bored with playing with it. The passages in the core are very very small and highly susceptible to dirty coolant, hence the miles / coolant question above.
The one thing in you description that is odd is the fact that the blower quit and then started again. Is this with the system in the Auto mode? If so, take it off Auto, set it to 72, and crank the fan. Drive it like this for a while and see if the fan goes off then back on.
Again, thank you for your quick response. The car currently has a few ticks over 93,800miles and from what I know has never had a coolant system service performed. I contacted a friend of mine who agreed with you on the heater core being clogged. I am taking it to him and doing a system check to see if any codes come up.
As far as the blower motors goes, it was on auto set at 72. I will do just that tonight and see if it goes off again.
The tech just revved the engine and flexed the coolant pipe at the front of the engine by hand and about 10 minutes later it started blowing hot. I had air coming out of the system for about a week afterwards. Had to keep topping up. But it's fine now.
