Help with check engine light?
<a href="http://www.purems.com/products/product.php/II=1472">Coolant Temp. Sensor</a>
The location for the sensor is shown here circled in red:
<img src="http://pictureposter.audiworld.com/107183/coolant_sensor.jpg">
It's just underneath the 3 connection hose (crank breather hose). I removed the hose when I changed mine, it gives you more space. Here is a link to DIY instructions on how to change the sensor, just scroll down the list and you will find it.
<a href="https://www.audiworld.com/tech/eng.html">DIY</a>
I'll need more time to check out your other DTC.
I also ocassionaly get the colant temp sensor DTC and clear the DTC and it takes a fairly long time to reappear. I will change the sensor in the spring as on the V6 it is slightly difficult to get at.
