If I am running ET47 wheels, should I get 10mm spacers?
If you're comfortable running spacers, they will help...
First, spacers will help the asthetics by pushing the wheels out a bit (they probably look pretty tucked right now). You could even do a 15mm spacer in the rear.
Second, you'll have proper clearance with them. An 8" wheel should ideally be around a 35 offset.
Here's a nice offset calculator to help you...
<a href="http://toy4two.home.mindspring.com/offset.html">Wheel Offset Calc</a>
Some people think spacers can be a bad idea...
because they change the geometry of the suspension and how the load is being distributed (handling can be compromised). You also have to make sure you get a good hubcentric spacer that will mate properly with the wheel and the hub or else vibration can occur because the wheel isn't spinning on it's axis. MTM and H&R both make good spacers with the right fitment.
Do a search of the archives to find many discussions on this (the S4 forum has some good info). Even people who are against them will agree that a 10mm spacer is pretty conservative and won't change things too much.
Don't say "no way" unless you have done all the research...
I'm not saying that a mild spacer is dangerous, but it's a fact that unless you're accounting for the spacer with a less aggressive wheel offset, you are causing more wear on the bearings than the manufacturer intended. Whether or not it's significant, I do not know for sure...
<a href="https://forums.audiworld.com/s4/msgs/1267598.phtml">NASA Racer's Post</a>
<i>"Saying "i use these and they're fine" does NOT negate 100 years of suspension technology anymore than "well I smoke a pack a day and don't have cancer" would demonstrate smoking is not dangerous."</i>
Jay-S8
18
05-07-2021 12:50 PM
N'Syncro
33
02-16-2020 03:12 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
Al_Bundy
09-02-2015 07:24 AM
