I'm pumped ! I pulled the trigger on ......
Zimmerman front rotors w/ Pagid sport pads.
Jordan at EVOMS was great. I highly recommend them. I also used Greedspeed for Neuspeed SS lines. Anthony was also very helpful and responsive. A brake fluid to be named later. Now....who will install???<ul><li><a href="http://www.evoms.com/">http://www.evoms.com/</a</li></ul> |
PES of course atlas! we can bug Ron for another hour or two
I had that exact setup on my B5 (Zimmerman x-drilled) and it was great. The only problem I had ,
was the high amount of brake dust the Pagid's put off. I must of had a problem with the pads because everyone I talked to said they were low dust compared to OEM pads. Just my luck.
Oh ya, I had regular brake lines. |
I have to price labor.......although.....
I have unused labor already at PES! I cancelled my plugs from Mach V....and ordered them from Greedspeed.
Cool....are you staying with the 1.8t diameter rotors...or did you go larger?
288 mm
how come i don't see any of that on the evoms website?
its wacky........sometimes the brake link on the L side menu does'nt show up
<ul><li><a href="http://www.evoms.com/a%20main%20frames.htm">http://www.evoms.com/a%20main%20frames.htm</a</li></ul>
Excellent...so they are providing the caliper brackets etc.?
Also, if you don't mind, how much was the setup? Thx.
The 288mm are the standard size rotors for the 1.8t.
