LOOSE TAIL LIGHTS
LOOSE TAIL LIGHTS
i will be sure to not write in all caps this time. So, my taillights i beleive are loose (or at least it seems to me). i was wondering if any of you guys had the same issue and if you have any ideas on how to make those little rubber prongs stay more firmly in the wholes. thanks!
OOOO
OOOO
I had this problem when I removed my Avant tail lights.
On mine the alignment nuts came loose on the inside of the body panel. If you tighten those down first (or at least screw them back in a little bit) and then screw in the tail light it should be nice and tight.
