Metallic clanking/rattling sound coming from rear of car at low speeds...any ideas?
Seems to only happen at really low speeds (5-10 mph) and not necessarily when going over bumps/potholes etc.) Definately happening in first gear, and maybe in second too. Haven't heard it at higher speeds because of wind/road noise, so I'm not sure if it's happening all the time or not.
I searched around a bit and saw that other were having a similar issue a while back and that it was potentially coming from something lose in the brakes or rear suspension. I didn't see anything affirmative on a cause/fix though, but noted that Audi seemed to be having trouble locating and actually addressing the problem. Brake problems sound like they were the result of a recent install/upgrade, but mine are stock as far as I know. Wondering if anyone had this issue and what the problem/solution was? Or any thoughts on what it might be/how to diagnose it?
2003 A4 3.0QM with 48k miles<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/530651.phtml">Post on rear suspension - seems similar</a></li></ul>
I had a similar noise a couple of weeks ago and it was a broken exhaust part
If you look at this pic you will see the 2 cross connecting arms connected together by a bolt
<img src="http://members.shaw.ca/mchammered/audi%20pics/new%20exhaust/IMG_3730.JPG">
Well the right hand piece broke off where it was welded from the pipe and I would hear a rattling sound when I start moving from the contact it was making with the exhaust.
Only when I took to my bodyshop did the guy who works on my car pick this out. He TIG welded the piece back on to where it was supposed to be and the noise went away.
Checked the exhaust, pretty sure thats not it...
Poked around underneath and gave everything a good shake/inspection. Nothing looked out of place and there were no issues with the cross members you mentioned.
Since I didn't have anyone around, I gave the car a few pushes and hopped out to see if I could see/hear anything. I didn't want to get it going to fast (cause I still need to hop in and hit the brakes), but I couldn't replicate the problem at those speeds (a quick walking pace, probably less than 5 mph). I drove back and forth a few times at closer to to 10 mph and could hear it in both reverse and 1st. It's definately coming from the rear! Thinking maybe something in the brakes?
Only have the OEM emergency jack so I didn't feel safe putting it up and trying to shake it around or crawl underneath it. Need to search more for the brake issues...
Stimps
09-14-2015 07:19 AM
Audi A6 2012 A6 3.0T Prestige (Atlanta)
QuickChange
09-04-2015 06:51 PM
Audi Other audi 100 control arm dorman aud100/520-717
rupenzelleo
08-30-2015 02:21 AM
