Misfire Cylinder 2.
Misfire Cylinder 2.
I ran a diagnostic on the car and got the code P0302 and did the following:
1. Pressure test on the motor. Got 12 bars on 5 cylinders and 11 on cylinder 4.
2. Changed the ignition coil from 1 to 2 and still read a missfire on 2.
3. Changed all 6 spark plugs, and still have the same missfire.
4. Changed the fuel injector on cylinder 2 and STILL have the same problem.
Does anyone know where I can go from here becuase I'm all out of ideas.
Thanks.
Thanks.
check to see if you have power and ground to your ignition coil...check for broken/melted wires and loose terminals at the coil pack...if all that checks out run a leakdown test on cyl 2
