my drivers door is messed up...none of the power buttons work.
was working fine yesterday...today i get in the car and i can't roll down any of the windows...footwell lights stay lit even when door is closed can't adjust mirrors and can't lock or unlock from the door. the alarm light blinks even though the door is unlocked and it doesn't lock when i lock it with the remote so my alarm doesn't activate...i have no clue...any help would be great...thanks
do the lights in the buttons come on when you have the headlights on?
only on the other doors...and actually i just checked and none of the windows go down
i checked all the fuses and all are ok...no i just took out all of my hyperwhite interior bulbs and changed them over to the factory ones...could that have something to do with it??
ugh the electronical system is shady im always worried
the lights on my drivers side door switches started to flicker so i...
opened the door and made sure the electrical connection between the door and the car was sung. It did the trick, no more flicker. I'm thinking that maybe (cheapest thought) yours somehow totally lost contact. try pushing the connector in, it is inside a rubber housing you can't miss it. mine worked w/o having to remove the rubber piece I just pushed hard both ways, toward the door and the body of the car. Let me know if it works.
The wires from my door to the chassis are all bare. The lock and speaker are wonky
Re: the lights on my drivers side door switches started to flicker so i...
does anybody know how to disconnect this connector? with my eyesight, it looks like there are some interlocks that slide/squeeze/snap before the connector comes free, but i cant tell which.
