N. McLean
Probably the above...there is a high and low float ?under the rear seats??.
I had to get my low float replaced......
then it read 3/4 when full for some time until it relearend the new float...supposedly...
Make sure the default values are replaced after you replace the sensor, as I believe that the computer compensates by changing those values as the sensor is failing over time...I could be wrong in this ..so input would be nice.
There is also info on simply cleaning the sensors...
http://www.audizine.com/forum/showth...l-sending-unit
radron26
04-28-2008 02:19 PM
