Need CV boot help.
Old Oct 16, 2010 | 05:35 PM
ScottJ's Avatar
Default Need CV boot help.
Haven't been on the forum in ages. Bet my sig isn't even accurate for the car colletion.
Still have my 2002 A4 Quattro 3.0 with 170,000 miles on it now.
However, I'm in desperate need of help. Found both inner CV boots split while doing an oil change.
Have gotten the passenger halfshaft out and cannot see a way to get the cup off the inner tripod. The end that bolts to the transmission looks welded and it won't pull apart the other way.
Fortunately I think I found the problem in time because I feel no excess slop, binding or grinding in the joint. I should be able to get away with just boots.
Did a search and saw someone had mentioned that the outer CV has to come off and the inner boot goes on that way. Is that so?
If the design really is that lame I might as well order and replace the outer boots while I'm at it.
Old Oct 16, 2010 | 07:55 PM
ScottJ's Avatar
Well, I believe I have my answer. A Facebook friend suggested there might be a clip inside the cup holding it on.
Nope. See attached. It's staked.
Guess I'm really lucky the joint seems to have survived its ordeal. No binding or grinding throughout its range of motion. Seems the only option would be to replace the shaft otherwise.
Old Oct 17, 2010 | 10:54 AM
AudiCO's Avatar
Not experienced with this job on the Audi, however I will say that on other vehicles it's easier to just replace the whole half shaft than to change the boots, as I guess you've already discovered. Keep the pics coming. Changed my oil last week and the CV boots looked like they were in great shape, but you never know.
Old Oct 19, 2010 | 09:22 AM
ScottJ's Avatar
FYI, I confirmed with the tech at Blau Parts that the intended service method is to pull the outer CV and slip the boot on that way. They can't even get the inner CV for my design. Just the whole shaft. Luckily the one I have out has no grinding or binding throughout its range of motion and no rotational slop to speak of. I hope the driver's side survived as well.
I ordered outer boots and axle bolts yesterday from Blau and they should be here tomorrow.
I was going to buy a slide hammer at Harbor Freight but I've read elsewhere you can just thread the axle bolt back in to pop the outer CV off. Going to give that a try before I spend any more money. I have already bought impact rated hex drivers for the axle bolt so I can use that on a impact gun to really apply some oomph.
shwndh
Dec 2, 2007 06:44 PM
OndrejAudiA420
Oct 8, 2007 09:17 AM
Rolf
Apr 8, 2007 05:07 PM
quattro90S6
12v V6 Discussion
Feb 22, 2004 07:57 AM
quattro90S6
Feb 21, 2004 08:08 AM
