Only warm air from the vents!
Hello,
I have a Audi A4 2002 2.0 Bensin.
I get only warm air from the vents except when i set the clima control to LOW.
The problem is on both sides?
Thanks,and sorry for bad english
No,control panel works fine,i can set it on auto or set manualy,i tried set it on eco but its always the same problem,i looked behind the glowbox,the stepermotor opens when i set LOW but closes all the way when i set anything other!
hope you will understand
Well, you've exceeded the easy stuff. The only other suggestion I have is to download codes using a VAGCOM reader and see what the car thinks is wrong.
sidespar
08-07-2006 11:09 AM
