Penny Mod...
Really a <b><u>DoorPlug Mod</u></b> for the door key hole
<img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp58%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E23238439584%3C5ot1lsi"><img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp46%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E2323843959%3B%3B3ot1lsi"> I originally thought I read of someone using a nickel but I test fitted one and it slightly too big... Well, something just a little less expensive works better. Here's how I did it: <u><b>Supplies/Tools:</b></u> - One Penny - A dab of <i>Bondo</i> - 150 grit sand paper - 800 grit sand paper - Primer Paint - Color Match Paint - Clearcoat Paint - 3M Mounting Squares or 3M 2X-Sided Tape - Cutting blade Fabrication & Install Time = 4 hours, Total Fabrication & Install Time = 30 minutes, elapsed time <center><u><b>Step One:</b></u> Break piggy bank and locate one penny <img src="http://images.snapfish.com/34376%3B2%3B23232%7Ffp45%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232384362%3B479ot1lsi"> <u><b>Step Two:</b></u> Prepare penny by 'roughing' surface to enhance bonding of <i>Bondo</i>. <img src="http://images.snapfish.com/34376%3B2%3B23232%7Ffp47%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232384362%3B486ot1lsi"><img src="http://images.snapfish.com/34376%3B2%3B23232%7Ffp64%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232384362%3B489ot1lsi"> <u><b>Step Three:</b></u> Slap some <i>Bondo</i> and hardening agent and mix <img src="http://images.snapfish.com/34376%3B2%3B23232%7Ffp63%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232384362%3B494ot1lsi"><img src="http://images.snapfish.com/34376%3B2%3B23232%7Ffp63%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232384362%3B498ot1lsi"> <u><b>Step Four:</b></u> Slop <i>Bondo</i> onto penny and press <i>Bondo</i> onto penny to free-up any voids <img src="http://images.snapfish.com/34376%3B2%3B23232%7Ffp58%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232384362%3B4%3A3ot1lsi"> <u><b>Step Five:</b></u> Let dry for 30 minutes <img src="http://images.snapfish.com/34376%3B2%3B23232%7Ffp46%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232384362%3B4%3A6ot1lsi"> <u><b>Step Six:</b></u> Sand w/150 grit to smooth surface while removing extra <i>Bondo</i> from penny edges <img src="http://images.snapfish.com/34376%3B2%3B23232%7Ffp47%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232384362%3B4%3A9ot1lsi"> <u><b>Step Seven:</b></u> Final sand w/800 grit to obtain smooth as glass finish <img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp63%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E2323843955%3B%3A%3Bot1lsi"> <u><b>Step Eight:</b></u> Apply 2 coats of primer paint and let dry 15 minutes between coats. <img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp63%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232384362%3B4%3B9ot1lsi"> <u><b>Step Nine:</b></u> Apply 3 coats of color match paint and let dry 15 minutes between coats. <img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp58%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E2323843955%3B%3B5ot1lsi"><img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp54%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E2323843955%3B%3B%3Bot1lsi"> <u><b>Step Ten:</b></u> Apply 2 coats of clearcoat paint and let dry 15 minutes between coats. <u><b>Step Eleven:</b></u> Cut out 3M mounting squares or 2X-sided tape equal to DoorPlug surface. <img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp4%3Enu%3D323%3B%3E558%3E459% 3EWSNRCG%3D32329348675%3B%3Bnu0mrj"><img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp63%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E2323843958537ot1lsi"> I used 3M Clear Mounting Squares because they are soft, tacky and pliable. <img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp64%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E23238436347%3C4ot1lsi"> <u><b>Step Twelve:</b></u> Apply to Door Key Hole <img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp46%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E2323843959%3B%3B3ot1lsi"> <u><b>Step Thirteen:</b></u> DONE !!! (Before & After) <img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp58%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E23238439584%3C5ot1lsi"><img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp54%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E2323843959%3B%3B7ot1lsi"> One may opt for the easy way out and pay a horrific $13.95 plus shipping from <a href="http://www.bumperplugs.com">BumperPlugs.com</a> Here's mine again and here's BumperPlugs.com <img src="http://images.snapfish.com/34376%3B%3A323232%7Ffp54%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E2323843959%3B%3B7ot1lsi"><img src="http://www.bumperplugs.com/photos/doorplug01.jpg"></center> Well, whatcha guys think??? Not bad for a penny !!! |
that's pretty slick. if i didn't use my keyhole for my turbo timer, i'd definetly do that
Re:yeah but how do you unlock the door ;) .after your remote gets dropped in the toilet NICE
Uh, Federal offense
...defacing money. Secret Service should be knocking down your door in about 3 minutes ;^)
Use that Fingernail trick to get the plug off.
Re: tell that to the makers of the machines that smash pennies into keep sakes.
LOL...$0.05 fine
Re: yeah i know.....that was the joke hense the wink....
I hate you.
no not really. geeze, i have to say this like once a week, Nice job ed.
I figured that...but sorry if I came off thinkin' yer a DA ;0
