Hello! I have a pretty big problem with my car, wipers, road lights, instrument cluster light and central locking do not work anymore.
I tried to change Instrument Cluster, but, problem persists..
Errors: (exlude errors from immobilizer, log was made with new IC and keys doesn t syncronized, now, i have put back original IC on car)
VCDS Version: Release 12.12.0
Data version: 20130910
Friday,03,May,2019,12:01:27:62939
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8EX2A226526 Mileage: 327320km/203387miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JL
Component: 1,9l R4 EDC G000SG 1519
Coding: 00002
Shop #: WSC 63351
VCID: 6ADB2423168A324E2A7-4A3A
WAUZZZ8E83A036631 AUZ6Z0B0122871
3 Faults Found:
18107 - Powertrain Data Bus
P1699 - 35-00 - Missing Message from Steering Wheel Electronics
18043 - Powertrain Data Bus
P1635 - 35-10 - Missing Message from A/C Controller - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5C1D71F7F949D36875-5000
4 Faults Found:
18036 - Powertrain Data Bus
P1628 - 35-10 - Missing Message from Steering Angle Sensor - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
01542 - Yaw Rate Sensor (G202)
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
VCID: 2A5BE423D60AF24EEA7-5000
12 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
01810 - Actuating Motor for Temperature Flap; Right (V159)
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
30-10 - Open or Short to Plus - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
30-10 - Open or Short to Plus- Intermittent
01232 - A/C Compressor Regulator Valve (N280)
01317 - Control Module in Instrument Cluster (J285)
49-00 - No Communications
01330 - Central Control Module for Central Convenience (J393)
00466 - Control Module for Steering Column Electronics (J527)
00457 - Control Module for Network (J519)
00474 - Control Module for Immobilizer
01336 - Data Bus for Comfort System
37-00 - Faulty
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: F4E7BA5B944E74BE00B-5000
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 F
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 00400
Shop #: WSC 00001
VCID: 2C57E23BDCFEEC7E18B-5000
WAUZZZ8EX2A226526 AUZ6Z0A0366389
11 Faults Found:
01039 - Coolant Temperature Sensor (G2)
00779 - Outside Air Temp Sensor (G17)
01177 - Engine Control Unit
65-10 - Unauthorized - Intermittent
01176 - Key
00576 - Terminal 15
27-00 - Implausible Signal
49-10 - No Communications - Intermittent
01331 - Door Control Module; Driver Side (J386)
01334 - Door Control Module; Rear Right (J389)
01333 - Door Control Module; Rear Left (J388)
37-00 - Faulty
01304 - Radio
End ---------------------------------------------------------------------
thank you in advance!
