RS4 Replica's
Okay, all you guys probably heard this question before...but I'll ask again. Who sells the best replica's? I heard Wheel Exchange and then I heard Tires.com. I want to run 235-40-18!
I was just about to make this same post! I'll add to it, who does the above mentioned, but also inc
includes the oem audi centercaps? Also, what is the correct tire size to run?
Re: I was just about to make this same post! I'll add to it, who does the above mentioned, but also
I've found that these wheels come with center caps from the replica's co., but cheap and not like OEM. You can purchase the OE caps for $20 ea. from Audi and modify them to fit. So far Discount Tires has the best fit. I just wanted to make sure they're the best replica's.
I think the offset of the wheels from Wheel Exchange are less than 35mm.. ~32mm i think..
also, be careful because I heard some replicas cant fit the OEM centercaps.. (from Clairparts.com for ~$20 each) .. so far I have heard that WheelExchange and Achtuning.com wheels can fit the OEM caps.. I think the ones from Performance alloys cant...
oh.. I think 235-40-18s are the best.. I wanted to run 245-35-18, but not too many companies
make them... which makes the tires pretty expensive..
Re: I think the offset of the wheels from Wheel Exchange are less than 35mm.. ~32mm i think..
Thanks, I'll look into it. Achtuning.com wheels I haven't look yet. I ordered the caps from Clairparts.com already. I'm looking for the best fit.
search for some posts about it I think someone wanted to get rid of them in SF area...
Don't know his screen name but he has a crystal blue A4.
I just learned this from another board, most of the wheels will take the oem center cap but..
they are 18x8. Performancealloys.com will not accept the oem center cap, but they are available in 18x8.5, something to consider...
I just got mine from Achtuning.com with OEM centercaps modified to fit... All part of the package!
